Aller au contenu principal
VTech InnoTab 2s Back Panel Replacement
Ce dont vous avez besoin
  1. VTech InnoTab 2s Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Back Panel Replacement: étape 2, image 1 de 2 VTech InnoTab 2s Back Panel Replacement: étape 2, image 2 de 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Back Panel Replacement: étape 3, image 1 de 3 VTech InnoTab 2s Back Panel Replacement: étape 3, image 2 de 3 VTech InnoTab 2s Back Panel Replacement: étape 3, image 3 de 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Back Panel Replacement: étape 4, image 1 de 2 VTech InnoTab 2s Back Panel Replacement: étape 4, image 2 de 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Back Panel Replacement: étape 5, image 1 de 2 VTech InnoTab 2s Back Panel Replacement: étape 5, image 2 de 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
Ricardo Espinosa
Membre depuis le 10/06/16
221 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 14
Total : 255
