Introduction
Exercise caution when lifting the LCD screen, as any excessive pulling can damage the motherboard. Otherwise, the LCD screen is one of the easiest parts of the device to replace and only requires a small amount of unscrewing, prying and gluing.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Magnetic Project Mat$16.96
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Heat the iOpener tool, then press the iOpener tool onto the connectors to heat the glue on the connector ribbon.
4 autres ont terminé cette réparation.
