Aller au contenu principal
VTech Kidizoom Camera Connect Power Distribution Circuit Board Replacement
Ce dont vous avez besoin
  1. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Front Case: étape 1, image 1 de 2 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Front Case: étape 1, image 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 2, image 1 de 2 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 2, image 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 3, image 1 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 3, image 2 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 3, image 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 4, image 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Motherboard: étape 5, image 1 de 1
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 6, image 1 de 2 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 6, image 2 de 2
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 7, image 1 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 7, image 2 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 7, image 3 de 3
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 8, image 1 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 8, image 2 de 3 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 8, image 3 de 3
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
  9. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Power Distribution Circuit Board: étape 9, image 1 de 1
    • Unsolder the wires connected to the power distribution circuit board.
  10. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 10, image 1 de 1
    • Locate and remove the two screws that hold in the power distribution circuit board using a Philips #0 screwdriver.
  11. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: étape 11, image 1 de 1
    • Gently pull up on power distribution circuit board and remove it from the device.
Justin Sanchez
Membre depuis le 02/08/16
520 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 membres
5 tutoriels rédigés
Un commentaire
The Camera is not working anymore. We can`t switch it on, so it could be that the distribution circiut is damaged.
What kind of disitrubution circiut is it? I want to order a spare part.
Babyface - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 19
Total : 1,329
