Aller au contenu principal
VTech Kidizoom Camera Connect Front Case Replacement
Ce dont vous avez besoin
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: étape 1, image 1 de 2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: étape 1, image 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: étape 2, image 1 de 2 VTech Kidizoom Camera Connect Front Case Replacement: étape 2, image 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: étape 3, image 1 de 3 VTech Kidizoom Camera Connect Front Case Replacement: étape 3, image 2 de 3 VTech Kidizoom Camera Connect Front Case Replacement: étape 3, image 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: étape 4, image 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Nick Foster
Membre depuis le 02/14/16
288 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 32
Total : 4,160
