Aller au contenu principal
VTech Kidizoom Camera Connect Shutter Button Replacement
Ce dont vous avez besoin
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: étape 1, image 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: étape 1, image 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: étape 2, image 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement: étape 2, image 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: étape 3, image 1 de 3 VTech Kidizoom Camera Connect Shutter Button Replacement: étape 3, image 2 de 3 VTech Kidizoom Camera Connect Shutter Button Replacement: étape 3, image 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: étape 4, image 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: étape 5, image 1 de 1
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: étape 6, image 1 de 1
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: étape 7, image 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement: étape 7, image 2 de 2
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
Justin Sanchez
Membre depuis le 02/08/16
544 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 1,270
