Aller au contenu principal
VTech Kidizoom Smartwatch DX2 Battery Replacement
Ce dont vous avez besoin
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: étape 1, image 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: étape 1, image 2 de 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 2, image 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 2, image 2 de 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 3, image 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 3, image 2 de 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 4, image 1 de 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 4, image 2 de 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 4, image 3 de 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: étape 5, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 6, image 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 6, image 2 de 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 7, image 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 7, image 2 de 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: étape 8, image 1 de 1
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: étape 9, image 1 de 1
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Jessica Richard
Membre depuis le 10/25/18
512 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 membres
7 tutoriels rédigés
4 commentaires
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Réponse
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 43
30 derniers jours : 107
Total : 9,166
