Aller au contenu principal
VTech Learning Tunes Karaoke Mode Selector Replacement
Ce dont vous avez besoin
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: étape 1, image 1 de 1
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 2, image 1 de 2 VTech Learning Tunes Karaoke Mode Selector Replacement: étape 2, image 2 de 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 3, image 1 de 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 4, image 1 de 2 VTech Learning Tunes Karaoke Mode Selector Replacement: étape 4, image 2 de 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 5, image 1 de 1
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 6, image 1 de 2 VTech Learning Tunes Karaoke Mode Selector Replacement: étape 6, image 2 de 2
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: étape 7, image 1 de 2 VTech Learning Tunes Karaoke Mode Selector Replacement: étape 7, image 2 de 2
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Adam Chaberek
Membre depuis le 02/09/16
137 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 14
Total : 286
