Aller au contenu principal
VTech Safe And Sound DM221 Buttons Replacement
Ce dont vous avez besoin
  1. VTech Safe And Sound DM221 Buttons Replacement, Buttons: étape 1, image 1 de 1
    • Remove the battery cover by sliding it down.
  2. VTech Safe And Sound DM221 Buttons Replacement: étape 2, image 1 de 1
    • Firmly grasp the battery and pull to disconnect the battery from its connector.
  3. VTech Safe And Sound DM221 Buttons Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 screwdriver, unscrew the two 5.0 mm screws located at the bottom of the monitor inside of the device.
  4. VTech Safe And Sound DM221 Buttons Replacement: étape 4, image 1 de 1
    • Using a plastic opening tool, pry apart the front part of the device from the back. There are many access points, but the best spot to insert the spudger is around the "TALK" button.
    • Avoid using the metal spudger. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  5. VTech Safe And Sound DM221 Buttons Replacement: étape 5, image 1 de 2 VTech Safe And Sound DM221 Buttons Replacement: étape 5, image 2 de 2
    • Remove the buttons from the front part of the device.
    • Tip: The buttons on the front of the device (“POWER,” “SELECT,” “MENU,” “VOLUME”) are all connected as one unit. Pull them out carefully.
Krystal
Membre depuis le 10/01/15
600 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 363
