Aller au contenu principal
VTech Safe And Sound DM221 Speaker Replacement
Ce dont vous avez besoin
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: étape 2, image 1 de 1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: étape 3, image 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: étape 4, image 1 de 1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: étape 5, image 1 de 1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: étape 6, image 1 de 1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: étape 7, image 1 de 1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: étape 8, image 1 de 1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: étape 9, image 1 de 1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Krystal
Membre depuis le 10/01/15
600 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 340
