Aller au contenu principal
VTech Spin and Learn Color Flashlight Red Ring Replacement
Ce dont vous avez besoin
  1. VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: étape 1, image 1 de 2 VTech Spin and Learn Color Flashlight Red Ring Replacement, Battery Housing: étape 1, image 2 de 2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: étape 2, image 1 de 3 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: étape 2, image 2 de 3 VTech Spin and Learn Color Flashlight Red Ring Replacement, Red Ring: étape 2, image 3 de 3
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  3. VTech Spin and Learn Color Flashlight Red Ring Replacement: étape 3, image 1 de 3 VTech Spin and Learn Color Flashlight Red Ring Replacement: étape 3, image 2 de 3 VTech Spin and Learn Color Flashlight Red Ring Replacement: étape 3, image 3 de 3
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
Nathaniel Troyer
Membre depuis le 08/27/15
441 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 2-6, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 2-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G6
3 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 15
Total : 328
