Aller au contenu principal
VTech Spin and Learn Color Flashlight Speaker Replacement
Ce dont vous avez besoin
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: étape 1, image 1 de 2 VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: étape 1, image 2 de 2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: étape 2, image 1 de 3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: étape 2, image 2 de 3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: étape 2, image 3 de 3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: étape 3, image 1 de 3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: étape 3, image 2 de 3 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: étape 3, image 3 de 3
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
Nathaniel Troyer
Membre depuis le 08/27/15
441 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 2-6, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 2-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G6
3 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 17
Total : 452
