Aller au contenu principal
VTech Write and Learn Creative Center Slider Replacement
Ce dont vous avez besoin
  1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: étape 1, image 1 de 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: étape 1, image 2 de 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: étape 1, image 3 de 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Slider Replacement, Slider: étape 2, image 1 de 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
Philip Zietkowski
Membre depuis le 03/25/16
345 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 583
