Aller au contenu principal
VTech Write and Learn Creative Center Speaker Replacement
Ce dont vous avez besoin
  1. VTech Write and Learn Creative Center Speaker Replacement, Back Panel: étape 1, image 1 de 3 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: étape 1, image 2 de 3 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: étape 1, image 3 de 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Speaker Replacement, Speaker: étape 2, image 1 de 3 VTech Write and Learn Creative Center Speaker Replacement, Speaker: étape 2, image 2 de 3 VTech Write and Learn Creative Center Speaker Replacement, Speaker: étape 2, image 3 de 3
    • In order to remove the speaker, you must desolder the two wires connecting it to the circuit board.
    • When you desolder, apply the tip of the soldering iron to the soldered joint for approximately 5 - 10 seconds.
    • The soldered joint will turn to a liquid consistency. At this moment, remove the wire and soldering iron.
    • Repeat each of the following steps for the second soldered joint.
    • Soldering irons are dangerously hot. The soldering iron should only come in contact with joints being desoldered or soldered.
    • Make sure to allow time for your soldering iron to heat up before using it.
    • Make sure the tip of the soldering iron is cleaned so the tin on the tip is exposed. This will allow the soldering iron to work efficiently.
  3. VTech Write and Learn Creative Center Speaker Replacement: étape 3, image 1 de 2 VTech Write and Learn Creative Center Speaker Replacement: étape 3, image 2 de 2
    • Remove the 2 5mm PH 0 Phillips screws with 10 mm heads that secure the speaker to the front of the case.
Victoria Hathaway
Membre depuis le 04/06/16
331 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
Where can I buy the speaker
Lesa Thomas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 1,356
