Aller au contenu principal
VanMoof No 3 Light Battery Replacement
Ce dont vous avez besoin
  1. VanMoof No 3 Light Battery Replacement, Battery: étape 1, image 1 de 3 VanMoof No 3 Light Battery Replacement, Battery: étape 1, image 2 de 3 VanMoof No 3 Light Battery Replacement, Battery: étape 1, image 3 de 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: étape 2, image 1 de 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: étape 3, image 1 de 2 VanMoof No 3 Light Battery Replacement, Remove the battery: étape 3, image 2 de 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: étape 4, image 1 de 2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: étape 4, image 2 de 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: étape 5, image 1 de 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: étape 5, image 2 de 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: étape 5, image 3 de 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: étape 6, image 1 de 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: étape 7, image 1 de 3 VanMoof No 3 Light Battery Replacement, Reassemble: étape 7, image 2 de 3 VanMoof No 3 Light Battery Replacement, Reassemble: étape 7, image 3 de 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: étape 8, image 1 de 2 VanMoof No 3 Light Battery Replacement, Reassemble 2: étape 8, image 2 de 2
    • Test the light turns on
    • Screw the back plate to the lense.
3 autres ont terminé cette réparation.
Martin Hampton
Membre depuis le 02/13/16
1 308 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 29
30 derniers jours : 132
Total : 7,712
