Aller au contenu principal
Velocity Micro Cruz T301 Motherboard Replacement
Ce dont vous avez besoin
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: étape 1, image 1 de 1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: étape 2, image 1 de 1
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: étape 3, image 1 de 1
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: étape 4, image 1 de 2 Velocity Micro Cruz T301 Motherboard  Replacement: étape 4, image 2 de 2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: étape 5, image 1 de 1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: étape 6, image 1 de 1
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: étape 7, image 1 de 1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: étape 8, image 1 de 1
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: étape 9, image 1 de 1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: étape 10, image 1 de 1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: étape 11, image 1 de 1
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: étape 12, image 1 de 2 Velocity Micro Cruz T301 Motherboard  Replacement: étape 12, image 2 de 2
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: étape 13, image 1 de 1
    • use openning tools to remove the motherboard.
Ahmed
Membre depuis le 10/05/16
227 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-6, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 183
