Aller au contenu principal
Velocity Micro Cruz T301 Speakers Replacement
Ce dont vous avez besoin
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: étape 1, image 1 de 1
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: étape 2, image 1 de 1
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: étape 3, image 1 de 1
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: étape 4, image 1 de 2 Velocity Micro Cruz T301 Speakers Replacement: étape 4, image 2 de 2
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: étape 5, image 1 de 1
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: étape 6, image 1 de 1
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: étape 7, image 1 de 1
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: étape 8, image 1 de 1
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: étape 9, image 1 de 1
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: étape 10, image 1 de 1
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: étape 11, image 1 de 1
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
Ali Rashid Al Araimi
Membre depuis le 10/05/16
371 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-6, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 120
