Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Velocity NoteMagix M10 A82 Keyboard Replacement
Ce dont vous avez besoin
  1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: étape 1, image 1 de 2 Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Keyboard Replacement: étape 2, image 1 de 2 Velocity NoteMagix M10 A82 Keyboard Replacement: étape 2, image 2 de 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Keyboard Replacement: étape 4, image 1 de 1
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Keyboard Replacement: étape 5, image 1 de 1
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
Sam Middleton
Membre depuis le 10/01/13
401 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 53
Total : 770
