Aller au contenu principal
Venturer CR20 Volume Wheel Replacement
Ce dont vous avez besoin
  1. Venturer CR20 Volume Wheel Replacement, Front Screen: étape 1, image 1 de 1
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Volume Wheel Replacement: étape 2, image 1 de 2 Venturer CR20 Volume Wheel Replacement: étape 2, image 2 de 2
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Volume Wheel Replacement, Power Cord: étape 3, image 1 de 2 Venturer CR20 Volume Wheel Replacement, Power Cord: étape 3, image 2 de 2
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Volume Wheel Replacement: étape 4, image 1 de 3 Venturer CR20 Volume Wheel Replacement: étape 4, image 2 de 3 Venturer CR20 Volume Wheel Replacement: étape 4, image 3 de 3
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  5. Venturer CR20 Volume Wheel Replacement, Tuner Wheel: étape 5, image 1 de 1
    • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  6. Venturer CR20 Volume Wheel Replacement: étape 6, image 1 de 2 Venturer CR20 Volume Wheel Replacement: étape 6, image 2 de 2
    • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  7. Venturer CR20 Volume Wheel Replacement: étape 7, image 1 de 3 Venturer CR20 Volume Wheel Replacement: étape 7, image 2 de 3 Venturer CR20 Volume Wheel Replacement: étape 7, image 3 de 3
    • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
    • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
    • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  8. Venturer CR20 Volume Wheel Replacement: étape 8, image 1 de 3 Venturer CR20 Volume Wheel Replacement: étape 8, image 2 de 3 Venturer CR20 Volume Wheel Replacement: étape 8, image 3 de 3
    • Gently, pull the tuner wheel up and away from the motherboard.
  9. Venturer CR20 Volume Wheel Replacement, Volume Wheel: étape 9, image 1 de 1
    • Gently, pull the volume wheel up and away from the motherboard.
Robert Myers
Membre depuis le 01/11/13
54 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-15, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 5-15, Forte Winter 2013
CPSU-FORTE-W13S5G15
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 13
Total : 345
