Aller au contenu principal
Verizon Ellipsis 10 Speaker Replacement
Ce dont vous avez besoin
  1. Verizon Ellipsis 10 Speaker Replacement, Back Cover: étape 1, image 1 de 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Speaker Replacement: étape 2, image 1 de 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Speaker Replacement: étape 3, image 1 de 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Speaker Replacement: étape 4, image 1 de 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Speaker Replacement, Battery: étape 5, image 1 de 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Speaker Replacement: étape 6, image 1 de 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Speaker Replacement: étape 7, image 1 de 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Speaker Replacement: étape 8, image 1 de 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Speaker Replacement: étape 9, image 1 de 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Speaker Replacement, Speaker: étape 10, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the four M1.5 screws from the right speaker.
  11. Verizon Ellipsis 10 Speaker Replacement: étape 11, image 1 de 1
    • Remove the black and white wires connected to the motherboard by pulling up on their connections.
    • Remove the three strips of tape.
  12. Verizon Ellipsis 10 Speaker Replacement: étape 12, image 1 de 1
    • Remove the four M1.5 screws on the left speaker.
    • Remove the speakers from the device.
Mary Duran
Membre depuis le 04/03/19
597 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 154
