Introduction
This guide provides detailed steps on fixing a mechanical issue within your ventilator on/off switch. This procedure will be useful if your unit will only power up as long as you hold the power switch in. This is a problem, as the device is designed to power up on a single push of the switch. To perform the following procedure, you will need a pair of pliers or tweezers. This is an easy fix and may take around 5 minutes.
For more information on replacing the switch, please refer to page 133 in the service manual.
Ce dont vous avez besoin
Use a pair of slim pliers or tweezers to grip the cap of the power switch button. Pull it straight out.
