Introduction
This repair guide will show the reader how to fix the Scroll Wheel on a VicTsing wireless mouse.
Remove the battery cover, and batteries from the compartment. Then use the metal spudger to  peel back the adhesives.
  • Remove the battery cover, and batteries from the compartment. Then use the metal spudger to peel back the adhesives.
Ajouter un commentaire
Use a Phillips #000 screwdriver to remove the 3 screws.
  • Use a Phillips #000 screwdriver to remove the 3 screws.
  • Carefully pull the base and upper casing away from each other.
  • Remove the two connected wire ports so that you can separate the top casing from the base .
  • This might take some effort, use the spudger if needed.
  • Remove the circuit board from the plastic base of the mouse.
  • Move the wheel away from the rotary encoder, and lift it to remove it.
  • Use tweezers to squeeze the rotary encoder. Do this in multiple spots.
  • Do not apply too much pressure to the rotary encoder or it will break.
  • Clean any dust or debris you see in the casing.
Ibrahim Elayan
Membre depuis le 22/02/2018
178 Réputation
1 tutoriel rédigé
Équipe
Very detailed repair guide!!!
Austin Melton - Réponse
THANK YOU! Saved me from spending another $10 on a mouse after 6 months. Those screws under the adhesives are pretty hidden…
Michael Shingo Crawford - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 44
Total : 128
