Aller au contenu principal
Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement
Ce dont vous avez besoin
  1. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: étape 1, image 1 de 3 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: étape 1, image 2 de 3 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement, Needle/Stylus: étape 1, image 3 de 3
    • Insert a prying tool into the stylus casing, right above the red casing.
    • Potential for device damage: Be delicate; if too much force is applied, the tone arm or stylus can break.
  2. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 2, image 1 de 2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 2, image 2 de 2
    • Push the casing down with the prying tool, releasing it so it can be removed.
  3. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 3, image 1 de 2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 3, image 2 de 2
    • Connect the new casing, applying it at an angle up and towards the back of the head of the tone arm.
  4. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 4, image 1 de 2 Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 4, image 2 de 2
    • Move the new casing up and into place where it will lock.
    • You should hear a click sound when securing the casing.
  5. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
    J'achète
  6. Victrola VTA-370B(PC)A Turntable Needle/Stylus Replacement: étape 6, image 1 de 1
    • Listen to how the turntable sounds when turned on. Listen for warbles, crackles, pops, and other non-desirable noise.
    • If these distortions are heard, the new stylus may not be installed correctly and should be reinstalled.
If the vinyl sounds clear and plays smoothly, the needle has been successfully installed and ready for use.
Ben Schnuck
Membre depuis le 02/25/21
133 Réputation
1 tutoriel rédigé
2 commentaires
My warranty is out (bought mine in 2017) and Victrola has been no help. They wont replace any parts, and so suggested I do an online search for 3rd party parts. But, I don’t even know what to look for. The arm on my unit is broken, what part do I need or what do I search for? I have the Model VTA-200B (music center with Bluetooth) Serial #: D170604182ITC. I tried to attach a pic, but can’t here.
Monica Addington - Réponse
Hi Monica,
After doing some research, it seems like you can only really replace the needle. If the arm is broken, you may need to find that individual with the plastic motor for sale online. But I'm not having luck finding any Victrola arms for sale either.
Cordell Johnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 55
Total : 3,311
