Aller au contenu principal
Pour réparer ensemble - Je crée un compte
VinoTemp VT-6TED
Ce dont vous avez besoin
Document vedette
  1. VinoTemp VT-6TED, Remove the Back Cover: étape 1, image 1 de 1
    • There are 10 philips screws holding the sheet metal back cover.
    • 3 screws along the top, 2 on 2 sides. And there are 3 on the bottom but the bottom is recessed, and one of them is covered by the factory sticker listing model information.
    Demander à FixBot
    Ajouter un commentaire
  2. VinoTemp VT-6TED, The circuit board: étape 2, image 1 de 1
    • At the top middle of the back of the VinoTemp is the circuit board. On the right side is the high voltage (120 VAC, 160 VDC).
    • On the left side of the circuit board is the low voltage, 12VDC. But the voltages can be around 10 or 11 VDC
    • The picture is of the left side, which is where the VinoTemp troubleshooting guide says to do your checking, using a Voltmeter.
    Demander à FixBot
  3. VinoTemp VT-6TED: étape 3, image 1 de 1
    • In the troubleshooting guide says, if the voltages look good (10 V to 12 VDC) you should to move on to the the Control circuit board. My voltages looked correct so I moved on.
    • But the Temperature Control circuit board is in the front, in the door of the VinoTemp. The small temperatue display is part of the temperature control circuit board.
    • To continue troubleshooting, you open the front door and disassemble it from the inside. But that is not what fixed my VinoTemp.
    Demander à FixBot
  4. VinoTemp VT-6TED: étape 4, image 1 de 1
    • The whole time I wwas troubleshooting, the VinoTemp had been plugged in and powered on. It had to be so that I could test the voltages.
    • I listed this as a "technique" on iFixit because I stumbled into getting my VinoTemp to work.
    • I realized I had not tested one of the voltages, the "cold" voltage, in the back on the main circuit board.
    • The voltage I didn't check is circled in Red. (the Blue circle is the ground side of the same circuit). When I pulled off the red tab, I heard a click (a relay) and the Hot side fan started running, and I heard the quiet buzzing inside the 'fridge. It's working!
    • I put the red wire back on and it kept working. I don't know why this reset the fridge but it did, and it's been working for 3 days now.
    Demander à FixBot
Attached is the 12 bottle VinoTemp service manual. I have not found the specific manual for the 6 bottle model. But the two models are very similar. I used this manual to guide me with my VinoTemp.
Allen
Membre depuis le 01/02/18
1 869 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 36
Total : 658
