This repair guide is for the Vintage Mini Vornado fan. After extended use, the blade on Vintage Mini Vornado fans can wear down and fail to produce a strong air flow. This guide demonstrates how to properly maintain and replace the blade. It is important that the fan is unplugged before starting the repair to avoid any accidents.
Prop the cap out of each hole with a pry tool to remove the blade cap.
To remove the blade cap, you will need to pop out three different areas of the cap from the fan. There are three small holes around the perimeter of the fan that the cap is secured into.
