Aller au contenu principal
Violin Bridge Replacement
Ce dont vous avez besoin
  1. Violin Bridge Replacement, Bridge: étape 1, image 1 de 2 Violin Bridge Replacement, Bridge: étape 1, image 2 de 2
    • Identify two sides of your violin. The violin bridge has one side that is higher than the other. The lower side is the E-string side.
    • E-string side
  2. Violin Bridge Replacement: étape 2, image 1 de 2 Violin Bridge Replacement: étape 2, image 2 de 2
    • Loosen the strings gently starting with the G-string and the E-string, then the D-string and the A-string.
    • G-string
    • E-string
    • D-string
    • A-string
    • Only loosen the strings until you can easily remove the bridge from under the strings without having to drag the bridge out.
  3. Violin Bridge Replacement: étape 3, image 1 de 2 Violin Bridge Replacement: étape 3, image 2 de 2
    • Remove the bridge gently from the violin.
  4. Violin Bridge Replacement: étape 4, image 1 de 2 Violin Bridge Replacement: étape 4, image 2 de 2
    • Mark the New bridge: Use a pencil or other marking tool to add 4 light marks where the 4 strings sit on the top of the new bridge.
    • The width should be wide enough so that when you are playing on only one string the bow won't produce noise from adjacent strings.
    • The width should also be narrow enough so that, when you are playing on two strings at the same time, you can use one finger to press on both these two strings without much difficulty.
    • Suggested horizontal distance between adjacent strings is 9-12mm. Adjust it based on your finger width. You can also use your old bridge as a guide for where to make marks if you please.
  5. Violin Bridge Replacement: étape 5, image 1 de 3 Violin Bridge Replacement: étape 5, image 2 de 3 Violin Bridge Replacement: étape 5, image 3 de 3
    • Place the new bridge between the center of the f-holes of your violin.
    • f-holes
    • Put the strings on your new bridge, align them with the marks you made in step 4.
  6. Violin Bridge Replacement: étape 6, image 1 de 3 Violin Bridge Replacement: étape 6, image 2 de 3 Violin Bridge Replacement: étape 6, image 3 de 3
    • Hold the bridge in one hand and tighten the strings in the reverse order you loosened them. That is, tighten the A-string and D-string first, and then, tighten the E-string and G-string. Tighten until each string matches its rough standard pitch (violin tuner suggested).
    • Continue to adjust the bridge to keep it perpendicular to the violin body every time you tighten the string so it is not leaning too far away from the f-holes.
    • After tightening all four strings, play a little to test the string placement. If the distance between the strings is not comfortable for performance (as noted in step 4), repeat step 2-6 and adjust the distance between the strings on the bridge again to find the proper distance.
  7. Violin Bridge Replacement: étape 7, image 1 de 2 Violin Bridge Replacement: étape 7, image 2 de 2
    • Finally, make any last adjustments to the bridge. Ensure that it is nearly perpendicular to the violin body. Also make sure that the feet of the bridge sit flat on the body of your violin.
Ligne d'arrivée
6 autres ont terminé cette réparation.
fldees
Membre depuis le 10/26/17
209 Réputation
1 tutoriel rédigé
Équipe
DePaul University, Team S1-G6, Dush Fall 2017 Membre de l'équipe DePaul University, Team S1-G6, Dush Fall 2017
DPU-DUSH-F17S1G6
2 membres
1 tutoriel rédigé
4 commentaires
Thanks for this guide. The bridge is considered to be an important part of the instrument and also said to be a soul of the instrument and its sound. The bridge should be always straight and perpendicular to the surface of the instrument. For some people, it may be difficult to replace the bridge all by their own, therefore it is necessary to take the violin to a violin shop where an experienced technician can either fix or replace the bridge. While the bridge is small and light, the way it is set up makes all the difference as far as how the violin will sound.
DellaBarnett - Réponse
Feet of the bridge must be fit. Bridge thickness adjusted. String heights are individual. This should only be done by a professional. This method is way too simple to make a bridge that is safe and actually functional for you violin.
fiddleronthehoof - Réponse
Agreed. And if the sound post falls over, good luck.
I would also debate the claim that this is one of the most essential tasks, and one that every violin player faces.
Patrick -
Help!!=( I dont know how to fix it!!
Vienna Davis-Friant - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 80
Total : 15,768
