Aller au contenu principal
Visual Land Prestige 7L Back Panel Replacement
Ce dont vous avez besoin
  1. Visual Land Prestige 7L Back Panel Replacement, Back Panel: étape 1, image 1 de 2 Visual Land Prestige 7L Back Panel Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Back Panel Replacement: étape 2, image 1 de 3 Visual Land Prestige 7L Back Panel Replacement: étape 2, image 2 de 3 Visual Land Prestige 7L Back Panel Replacement: étape 2, image 3 de 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Back Panel Replacement: étape 3, image 1 de 3 Visual Land Prestige 7L Back Panel Replacement: étape 3, image 2 de 3 Visual Land Prestige 7L Back Panel Replacement: étape 3, image 3 de 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
Robert
Membre depuis le 01/28/15
141 Réputation
1 tutoriel rédigé
Équipe
Penn State, Team 2-25, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 516
