Aller au contenu principal
Visual Land Prestige 7L Screen Replacement
Ce dont vous avez besoin
  1. Visual Land Prestige 7L Screen Replacement, Back Panel: étape 1, image 1 de 2 Visual Land Prestige 7L Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Screen Replacement: étape 2, image 1 de 3 Visual Land Prestige 7L Screen Replacement: étape 2, image 2 de 3 Visual Land Prestige 7L Screen Replacement: étape 2, image 3 de 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Screen Replacement: étape 3, image 1 de 3 Visual Land Prestige 7L Screen Replacement: étape 3, image 2 de 3 Visual Land Prestige 7L Screen Replacement: étape 3, image 3 de 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Screen Replacement, Screen: étape 4, image 1 de 3 Visual Land Prestige 7L Screen Replacement, Screen: étape 4, image 2 de 3 Visual Land Prestige 7L Screen Replacement, Screen: étape 4, image 3 de 3
    • Remove the tape holding the motherboard, wires, and connecters in place.
  5. Visual Land Prestige 7L Screen Replacement: étape 5, image 1 de 3 Visual Land Prestige 7L Screen Replacement: étape 5, image 2 de 3 Visual Land Prestige 7L Screen Replacement: étape 5, image 3 de 3
    • Unclip the three connectors by gently pulling the rear panel up and away from the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Pull out each of the gold connections.
    • The gold connections will disconnect from the motherboard, but not entirely from the device. Let them sit loosely where they are attached and be careful not to tear them when working in their proximity on the device.
  6. Visual Land Prestige 7L Screen Replacement: étape 6, image 1 de 1
    • Remove the seven 4mm Phillips Head screws that hold the touchscreen panel and motherboard together.
  7. Visual Land Prestige 7L Screen Replacement: étape 7, image 1 de 3 Visual Land Prestige 7L Screen Replacement: étape 7, image 2 de 3 Visual Land Prestige 7L Screen Replacement: étape 7, image 3 de 3
    • Gently flip over the motherboard and begin to use the spudger to pry away the touchscreen panel from the front screen.
3 autres ont terminé cette réparation.
Zach
Membre depuis le 01/28/15
486 Réputation
2 tutoriels rédigés
Équipe
Penn State, Team 2-25, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 membres
4 tutoriels rédigés
Un commentaire
Muchas gracias por tan importante aporte a la comunidad; desde Colombia  con respeto. Atte. GAZUTEC
GAZUTEC - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 657
