Introduction
This guide will show you how to remove the back panel to get to the components inside the tablet.
Pièces
Aucune pièce nécessaire.
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Ajouter un commentaire
Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
  • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
  • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
6 autre(s) ont terminé cette réparation.
Max Hudson
Membre depuis le 14/10/2014
422 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-41, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,395
