Aller au contenu principal
Vivitar Vivicam T027 Power Button Replacement
Ce dont vous avez besoin
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: étape 1, image 1 de 2 Vivitar Vivicam T027 Power Button Replacement, Power Button: étape 1, image 2 de 2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: étape 2, image 1 de 1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: étape 3, image 1 de 2 Vivitar Vivicam T027 Power Button Replacement: étape 3, image 2 de 2
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: étape 4, image 1 de 1
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: étape 5, image 1 de 2 Vivitar Vivicam T027 Power Button Replacement: étape 5, image 2 de 2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
Dana
Membre depuis le 03/11/15
110 Réputation
1 tutoriel rédigé
Équipe
Marist, Team 15-13, Laflen Spring 2015 Membre de l'équipe Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 14
Total : 874
