Aller au contenu principal
Vivitar Vivicam T027 Screen Replacement
Ce dont vous avez besoin
  1. Vivitar Vivicam T027 Screen Replacement, Screen: étape 1, image 1 de 2 Vivitar Vivicam T027 Screen Replacement, Screen: étape 1, image 2 de 2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: étape 2, image 1 de 1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: étape 3, image 1 de 2 Vivitar Vivicam T027 Screen Replacement: étape 3, image 2 de 2
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: étape 4, image 1 de 1
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: étape 5, image 1 de 1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: étape 6, image 1 de 1
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: étape 7, image 1 de 2 Vivitar Vivicam T027 Screen Replacement: étape 7, image 2 de 2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Nicole Knoebel
Membre depuis le 03/11/15
258 Réputation
2 tutoriels rédigés
Équipe
Marist, Team 15-13, Laflen Spring 2015 Membre de l'équipe Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 membres
3 tutoriels rédigés
2 commentaires
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Réponse
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 9
Total : 776
