Introduction
This guide will help users remove a broken Vizio CT15 display screen.
Pièces
Aucune pièce nécessaire.
  1. Turn the laptop off and remove all power cables. Remove the six Phillips #0 screws.
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Remove the six Phillips #0 screws.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  5. Using your fingers, unplug the wires. Using your fingers, unplug the wires. Using your fingers, unplug the wires.
    • Using your fingers, unplug the wires.
  6. Remove the six Phillips #0 screws. Disconnect the display from the laptop base by pulling the two apart from each other.
    • Disconnect the display from the laptop base by pulling the two apart from each other.
Brian Patino
Membre depuis le 21/02/2018
234 Réputation
2 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 104
