Introduction
This guide will help users replace their Vizio CT15 keyboard when the whole keyboard is not responding.
  1. Turn the laptop off and remove all power cables. Remove the six Phillips #0 screws.
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Remove the six Phillips #0 screws.
  3. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop. Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Unplug the wire connecting the speakers to the motherboard. Unplug the wire connecting the speakers to the motherboard.
    • Unplug the wire connecting the speakers to the motherboard.
  5. Remove the four Phillips #0 screws. Pull the speakers out to remove.
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  7. Use the flat end of a spudger to lift up the black tab on the ZIF connector. Pull the ribbon cables out of the ZIF connector. These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  8. Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop. Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  9. Unplug the fan from the motherboard. Unplug the fan from the motherboard.
    • Unplug the fan from the motherboard.
  10. Remove the three Phillips #0 screws. Pull the fan out to remove.
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  11. Remove the four Philips #0 screws from the heatsink. Pull up and out to remove the heatsink from the laptop.
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  12. Remove the eight Phillips #0 screws from the motherboard. Lift the motherboard up and out to remove it from the laptop.
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  13. Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  14. Use a metal spudger to carefully push the keyboard out of place. Carefully flip the laptop over and pull the keyboard out. Carefully flip the laptop over and pull the keyboard out.
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
2 autre(s) ont terminé cette réparation.
jalon
Membre depuis le 07/03/2018
112 Réputation
1 tutoriel rédigé
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 23
Total : 239
