Aller au contenu principal
Vizio Tablet Micro USB Charging Port Replacement
Ce dont vous avez besoin
  1. Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: étape 1, image 1 de 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: étape 1, image 2 de 3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: étape 1, image 3 de 3
    • Begin by using the plastic opening tool to take off the back of the tablet.
    • Starting from the sides can make the process easier.
  2. Vizio Tablet Micro USB Charging Port Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to disconnect the LCD screen.
  3. Vizio Tablet Micro USB Charging Port Replacement: étape 3, image 1 de 1
    • Use the plastic opening tool to disconnect the camera.
  4. Vizio Tablet Micro USB Charging Port Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool to disconnect both of the volume buttons.
  5. Vizio Tablet Micro USB Charging Port Replacement: étape 5, image 1 de 2 Vizio Tablet Micro USB Charging Port Replacement: étape 5, image 2 de 2
    • Then, remove all four of the 2.3 mm Phillips screws.
  6. Vizio Tablet Micro USB Charging Port Replacement: étape 6, image 1 de 1
    • Remove the circuit board from the platform.
  7. Vizio Tablet Micro USB Charging Port Replacement: étape 7, image 1 de 1
    • Remove the USB port from the circuit board.
  8. Vizio Tablet Micro USB Charging Port Replacement: étape 8, image 1 de 1
    • Insert the new USB port onto the circuit board.
  9. Vizio Tablet Micro USB Charging Port Replacement: étape 9, image 1 de 1
    • Lastly, fuse the USB port back onto the circuit board.
Jose
Membre depuis le 05/31/16
125 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Thank you it was very helpful simple and straight to the point
sirhc89chris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 8
Total : 932
