Introduction
If your Voluas VL001 pet feeder is having problems with dispensing any food, you may have an issue with your electric motor. The motor that turns the mechanism to dispense food can burn up, which requires replacement to fix.
This replacement requires special skills like wire stripping and soldering.
Ce dont vous avez besoin
Remove the lid to the storage tank by using the latch and lifting off.
Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
Place your pet feeder upside down.
Squeeze the lock and remove the battery cover.
Remove the three 1.5V D alkaline batteries.
Insert a metal spudger under the adhesive part of each rubber foot.
Pry the foot off.
Using a Phillips #2 screwdriver, remove the six 11.2 mm screws that hold the motor housing on to the device.
Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
You will want to see a score line in the insulation all around the wire like this.
Pull the end of the insulation off, exposing the wire.
