Aller au contenu principal
Vornado 133 Compact Air Circulator Fuse Replacement
Ce dont vous avez besoin
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: étape 1, image 1 de 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: étape 2, image 1 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: étape 2, image 2 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: étape 2, image 3 de 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: étape 3, image 1 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: étape 3, image 2 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 autres ont terminé cette réparation.
Erin Klein
Membre depuis le 07/06/17
483 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G2, Liner Summer 2017 Membre de l'équipe UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 membres
4 tutoriels rédigés
10 commentaires
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Réponse
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Réponse
Fast-acting or slow-acting?
James Olsen - Réponse
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Réponse
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 29
30 derniers jours : 87
Total : 33,709
