Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Vorwerk Kobold VR200 battery exchange/removal
Ce dont vous avez besoin
  1. Vorwerk Kobold VR200 battery exchange/removal, Turn off robot: étape 1, image 1 de 2 Vorwerk Kobold VR200 battery exchange/removal, Turn off robot: étape 1, image 2 de 2
    • Turn off the robot via the "Settings" > "Turn off robot" menu.
  2. Vorwerk Kobold VR200 battery exchange/removal, Turn the Robot: étape 2, image 1 de 2 Vorwerk Kobold VR200 battery exchange/removal, Turn the Robot: étape 2, image 2 de 2
    • Turn the robot over and place it on a suitable, soft surface. Make sure that the robot does not lie directly on the dome.
    • Use either two soft wooden slats or a small and sturdy cardboard box.
  3. Vorwerk Kobold VR200 battery exchange/removal, Remove Torx Screws: étape 3, image 1 de 1
    • Now remove the two screws 3.5x14mm with a Torx screwdriver T10
  4. Vorwerk Kobold VR200 battery exchange/removal, Remove Battery Cover: étape 4, image 1 de 2 Vorwerk Kobold VR200 battery exchange/removal, Remove Battery Cover: étape 4, image 2 de 2
    • Now pry open the battery cover with a suitable tool (plectrum or plastic opening tool). Make sure that there are two latches on the opposite side of the screws. The cover must therefore be lifted from the screw-on side.
  5. Vorwerk Kobold VR200 battery exchange/removal, Remove the Battery: étape 5, image 1 de 2 Vorwerk Kobold VR200 battery exchange/removal, Remove the Battery: étape 5, image 2 de 2
    • Removing the battery is a bit difficult. One possibility is that you use the plastic opening tool to remove the foam tape on the left and right side of the battery.
    • Then you can use both hands to lift the battery by the "ears" of the tape.
  6. Vorwerk Kobold VR200 battery exchange/removal, Disconnect the Battery: étape 6, image 1 de 2 Vorwerk Kobold VR200 battery exchange/removal, Disconnect the Battery: étape 6, image 2 de 2
    • Disconnect the 4-pin plug of the battery by first pressing the latch and then pulling out the plug.
Now the replacement battery can be connected!
Work the steps in reverse order to reassemble your device.
13 autres ont terminé cette réparation.
Merci à ces traducteurs :
de en
100%
oldturkey03 nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Pixel-Pete
Membre depuis le 04/25/22
593 Réputation
1 tutoriel rédigé
6 commentaires de tutoriel
Vielen Dank für die sehr gute Anleitung. Jetzt läuft mein kleiner wieder 😀.
Bianca - Réponse Partager
Bin begeistert! Vielen DANK!! Ich hatte dieselben Fehler, jetzt laufen sowohl Fernbedienung als auch das Bedienfeld auf dem Display.
Silvia Hackmann - Réponse Partager
Hallo,
mein Sauger läßt sich nicht wie in Schritt 1 beschrieben komplett ausschalten. Kann ich den Akku trotzdem wechseln?
katzenfrau53 - Réponse Partager
Hallo, klappt das so auch beim vr300? Ich habe gehört dort muss der Akku wieder angelernt werden?
Matthias Pfeifer - Réponse Partager
Eigendlich logisch, dennoch gutes Manual. Gibt es noch einen „Hotkey“ damit der Robot auch weiss, das es einen neuen Accu gibt? Die SW Einstellung „Neuer Accu“ verursacht einen unnötigen Ladungsvorgang….
Ulrich Schmitz - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 99
30 derniers jours : 327
Total : 18,376
