Introduction
Is the microphone not working properly on your childs tablet? This guide will walk you through replacing the microphone on the Vtech InnoTab 3s.
Ce dont vous avez besoin
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Solder the prongs to unsecure the microphone from the device.
Using the tweezers carefully remove the microphone from the device.
