Introduction
Is your InnoTab 3S screen cracked? This guide will walk you through replacing the screen of the Vtech InnoTab 3S.
Ce dont vous avez besoin
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Open the clip holding the screen plug with the yellow film.
Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
4 commentaires
What is the part number for the screen. Where can I buy one. Thank you.
what is the size of the screen
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
Where can I buy the replacement screen for the Vtech innotab 3S
