Aller au contenu principal
Vtech InnoTab 3S Speaker Replacement
Ce dont vous avez besoin
  1. Vtech InnoTab 3S Speaker Replacement, Rear Panel: étape 1, image 1 de 3 Vtech InnoTab 3S Speaker Replacement, Rear Panel: étape 1, image 2 de 3 Vtech InnoTab 3S Speaker Replacement, Rear Panel: étape 1, image 3 de 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Speaker Replacement: étape 2, image 1 de 2 Vtech InnoTab 3S Speaker Replacement: étape 2, image 2 de 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Speaker Replacement: étape 3, image 1 de 3 Vtech InnoTab 3S Speaker Replacement: étape 3, image 2 de 3 Vtech InnoTab 3S Speaker Replacement: étape 3, image 3 de 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Speaker Replacement: étape 4, image 1 de 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Speaker Replacement, Motherboard: étape 5, image 1 de 2 Vtech InnoTab 3S Speaker Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Speaker Replacement: étape 6, image 1 de 1
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Speaker Replacement, Speaker: étape 7, image 1 de 2 Vtech InnoTab 3S Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Looking at the front of the motherboard, the speakers are located in the bottom left of the device. They are shaped like a large black circle.
    • Using a soldering iron, heat the connections securing the speakers to the motherboard of the device.
    • Remove the connections on the motherboard to detach the speaker.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
taweewatchulikavit
Membre depuis le 08/27/15
341 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 8-2, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 652
