Introduction
This guide will walk you through replacing the USB port on your childs Vtech InnoTab 3S.
Ce dont vous avez besoin
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
2 autres ont terminé cette réparation.
