Aller au contenu principal
Vtech Kidibeats Drum Set Battery Replacement
Ce dont vous avez besoin
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: étape 2, image 1 de 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: étape 3, image 1 de 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: étape 4, image 1 de 1
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
Aaron Klementowski
Membre depuis le 02/09/16
820 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 2-8, Cagle Spring 2016 Membre de l'équipe USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 946
