Aller au contenu principal
Vtech Kidibeats Drum Set Speaker Replacement
Ce dont vous avez besoin
  1. Vtech Kidibeats Drum Set Speaker Replacement, Back Panel: étape 1, image 1 de 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Speaker Replacement: étape 2, image 1 de 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Speaker Replacement: étape 3, image 1 de 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Speaker Replacement: étape 4, image 1 de 1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Speaker Replacement: étape 5, image 1 de 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Speaker Replacement: étape 6, image 1 de 2 Vtech Kidibeats Drum Set Speaker Replacement: étape 6, image 2 de 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Speaker Replacement, Speaker: étape 7, image 1 de 1
    • Loosen and remove the two 10mm screws using a Phillips #00 screwdriver.
  8. Vtech Kidibeats Drum Set Speaker Replacement: étape 8, image 1 de 1
    • Using your hand, gently remove speaker from its housing.
  9. Vtech Kidibeats Drum Set Speaker Replacement: étape 9, image 1 de 1
Aaron Klementowski
Membre depuis le 02/09/16
820 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 2-8, Cagle Spring 2016 Membre de l'équipe USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 603
