Aller au contenu principal
Vtech Move and Crawl Ball Motor Replacement
Ce dont vous avez besoin
  1. Vtech Move and Crawl Ball Motor Replacement, Battery: étape 1, image 1 de 2 Vtech Move and Crawl Ball Motor Replacement, Battery: étape 1, image 2 de 2
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
  2. Vtech Move and Crawl Ball Motor Replacement: étape 2, image 1 de 3 Vtech Move and Crawl Ball Motor Replacement: étape 2, image 2 de 3 Vtech Move and Crawl Ball Motor Replacement: étape 2, image 3 de 3
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
  3. Vtech Move and Crawl Ball Motor Replacement, Motor: étape 3, image 1 de 3 Vtech Move and Crawl Ball Motor Replacement, Motor: étape 3, image 2 de 3 Vtech Move and Crawl Ball Motor Replacement, Motor: étape 3, image 3 de 3
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
  4. Vtech Move and Crawl Ball Motor Replacement: étape 4, image 1 de 3 Vtech Move and Crawl Ball Motor Replacement: étape 4, image 2 de 3 Vtech Move and Crawl Ball Motor Replacement: étape 4, image 3 de 3
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
William Jones
Membre depuis le 09/04/15
222 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-1, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 2-1, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G1
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,719
