Introduction
In this guide it is not necessary to replace the motor but you do need to move it out of the way to reach the switch.
Ce dont vous avez besoin
There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
Remove 6 screws in order to pop off the outer shell and reach the inside components.
Unscrew the two screws to the power switch located beside the circuit board
