Aller au contenu principal
Vtech Touch and Swipe Baby Phone Power Switch Replacement
Ce dont vous avez besoin
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: étape 1, image 1 de 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: étape 1, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 2, image 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 2, image 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 2, image 3 de 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 3, image 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 3, image 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 3, image 3 de 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: étape 4, image 1 de 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: étape 4, image 2 de 2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 5, image 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 5, image 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: étape 5, image 3 de 3
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
tellocordova
Membre depuis le 09/04/15
342 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-4, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 membres
12 tutoriels rédigés
2 commentaires
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Réponse
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 627
