Aller au contenu principal
Vulcan Venture II VNB14002IE I/O Board Replacement
Ce dont vous avez besoin
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: étape 1, image 1 de 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: étape 2, image 1 de 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: étape 3, image 1 de 1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: étape 4, image 1 de 2 Vulcan Venture II VNB14002IE I/O Board Replacement: étape 4, image 2 de 2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: étape 5, image 1 de 2 Vulcan Venture II VNB14002IE I/O Board Replacement: étape 5, image 2 de 2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: étape 6, image 1 de 1
    • The IO Board is now safe to remove from the computer.
Parish Brandt
Membre depuis le 09/21/18
615 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 525
