Introduction
Use this guide to drain the oil on a Wacker BS50-4AS REV 101 (2019) Vibrator/Rammer.
This model requires up to 0.7 liters of SAE 10W-40 oil to replace drained oil.
Ce dont vous avez besoin
Firmly grip the base of the spark plug wire's connector and pull it away from the spark plug to disconnect it.
Use a 1-1/16 inch socket to break loose the oil sight gauge near the bottom of the device.
Lay the device down horizontally with the oil sight gauge facing down.
Position a shallow oil drain pan underneath the sight gauge.
Remove the oil sight gauge.
Let the oil drain until drips are infrequent.
Replace and retighten the oil sight gauge.
