Introduction
Frequent use can damage or jam the buttons on the Cintiq 24HD over time. You can not properly adjust the display of the Cintiq 24HD without the buttons . This guide will walk you through replacing the display control buttons on the Cintiq 24HD.
Pièces
Aucune pièce spécifiée.
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
Remove metal holding plate by lifting up and off of the button board.
