Introduction
by the end of the guide you will have replaced your power supply
Ce dont vous avez besoin
Procurement of a suitable commercially available power pack.
Type GST120A24R7B
R7B is important as this is the only connector that fits the Wacom tablet. (Connector type KYCON KPPX-4).
Performance data 120W, 24 volts
The power pack opens. To do this, the four rubber plugs are removed and the four screws are removed with a Phillips screwdriver. The housing can then be easily removed.
The 24V side has four wires: black, blue, red and white. These are soldered and can be removed.
The black and blue wire is soldered to the minus output (V-). The red and white wire is soldered to the 24V (V+) output. Note: The black wire is connected to the metal body of the plug.
The power supply will reassemble and can now be connected to the Wacom Tablet.
Work the steps in reverse order to reassemble your device.
Merci à ces traducteurs :
100%
HelloMacOS nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
