Introduction
The USB video port on the Wacom Cintiq 24HD allows you to connect the device to any computer with a USB connector. Extended use can damage or render the video port non-functional. This guide will show you how to replace the USB port. You need basic soldering skills and a soldering kit for this replacement guide. iFixit has a guide to soldering which you can find here.
Pièces
Aucune pièce spécifiée.
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
Remove the one 6.8mm Phillips #1 screw by turning the screwdriver counterclockwise.
